Danger
Potentiellement dangereux
Risque de blessure si cette procédure n'est pas suivie correctement. Faites preuve de prudence et suivez tous les avertissements.
Danger
Introduction
Your B212D contains a case filled with a metal box that contains all the electronics, except for the speakers. You will be removing this electronics box to access the case's internal space - you know, in case you need to stash $1,000,000 dollars in there to hide it from the CIA! :)
Pièces
Aucune pièce nécessaire.
Unplug your speaker from the power outlet.
  • Unplug your speaker from the power outlet.
  • Remove the 8 Phillips screws from the back of the speaker.
Ajouter un commentaire
Carefully remove the back panel, lifting out the metal electronics-box with it.
  • Carefully remove the back panel, lifting out the metal electronics-box with it.
  • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
gameslammer7
Membre depuis le 29/03/2012
861 Réputation
6 tutoriels rédigés
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - Réponse
I will wait for answer
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 37
Total : 1,993
