Aller au contenu principal
Removing the Dell Inspiron 1150 Keyboard
Ce dont vous avez besoin
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: étape 1, image 1 de 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: étape 1, image 2 de 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: étape 1, image 3 de 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: étape 2, image 1 de 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: étape 2, image 2 de 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: étape 2, image 3 de 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: étape 3, image 1 de 3 Removing the Dell Inspiron 1150 Keyboard: étape 3, image 2 de 3 Removing the Dell Inspiron 1150 Keyboard: étape 3, image 3 de 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
Richdave
Membre depuis le 04/09/10
32 177 Réputation
30 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 468 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 17
Total : 881
