Aller au contenu principal
Removing the Dell Inspiron 1150 Modem Card
Ce dont vous avez besoin
  1. Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: étape 1, image 1 de 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: étape 1, image 2 de 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: étape 1, image 3 de 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: étape 2, image 1 de 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: étape 2, image 2 de 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: étape 2, image 3 de 3
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: étape 3, image 1 de 2 Removing the Dell Inspiron 1150 Modem Card: étape 3, image 2 de 2
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: étape 4, image 1 de 2 Removing the Dell Inspiron 1150 Modem Card: étape 4, image 2 de 2
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Ligne d'arrivée
Lauren
Membre depuis le 04/25/10
4 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 16-2, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 4,504
