Introduction
This guide will show you how to locate and remove the Bluetooth module
Pièces
Aucune pièce nécessaire.
Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
  • Flip laptop over and locate the battery release button
  • Push release button to the left to release battery and gently pull battery from the laptop
Ajouter un commentaire
Locate the Bluetooth module cover on the bottom of the laptop Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
  • Locate the Bluetooth module cover on the bottom of the laptop
  • Loosen the M2.0×5.0 captive screw and remove the cover by by lifting it straight up
  • The Bluetooth module is connected to the laptop via a small cable with very fine wires - take care not to damage the cable when you pull the module out of the case.
  • Gently lift the Bluetooth module up and over the retaining clip. A plastic spudger may be useful.
  • Disconnect the connector being careful not to damage the fine wires on the cable.
3 autre(s) ont terminé cette réparation.
Richdave
Membre depuis le 09/04/2010
27 525 Réputation
37 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 33
Total : 3,590
