Introduction
This guide will show you how to locate and remove the WLAN (WiFi) module.
Pièces
Aucune pièce nécessaire.
Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
  • Flip laptop over and locate the battery release button
  • Push release button to the left to release battery and gently pull battery from the laptop
Ajouter un commentaire
Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard Slide the retention clips toward the keyboard to release the keyboard
  • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
  • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
  • Slide the retention clips toward the keyboard to release the keyboard
Use a plastic pry tool to lift the rear edge of the keyboard. Pull  the keyboard slightly towards the display to disengage  the tabs along the front of the keyboard from the laptop palm rest. Lift the keyboard up to reveal the ribbon connectors
  • Use a plastic pry tool to lift the rear edge of the keyboard.
  • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
  • Lift the keyboard up to reveal the ribbon connectors
After loosening the four moveable tabs at the screen end you simply pull slightly to the right to loosen the left side and then up to loose the five tabs in the lower end, then flip keyboard over so keys face the screen.
e5frog - Réponse
Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable Release the smaller ribbon cable by lifting up the white retainer I found it easier to reinstall both cables with the new keyboard resting on the back edge
  • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
  • Release the smaller ribbon cable by lifting up the white retainer
  • I found it easier to reinstall both cables with the new keyboard resting on the back edge
There is no need at all to loosen any ribbon cables, after flipping keyboard so it faces keys against screen you can simply remove the RAM. Don't fiddle with the ribbon cables.
e5frog - Réponse
Locate the WLAN module Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module. The antenna wires are colour coded tabs on them for easy reinstallation so be sure to take note of the correct order.  there are coloured tabs on the wires!
  • Locate the WLAN module
  • Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
  • The antenna wires are colour coded tabs on them for easy reinstallation so be sure to take note of the correct order. there are coloured tabs on the wires!
  • Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
  • With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
2 autre(s) ont terminé cette réparation.
Richdave
Membre depuis le 09/04/2010
27 519 Réputation
37 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
274 membres
713 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 59
Total : 5,159
