Aller au contenu principal
Removing the HP Elitebook 6930p modem card
Ce dont vous avez besoin
  1. Removing the HP Elitebook 6930p modem card, Battery Removal: étape 1, image 1 de 3 Removing the HP Elitebook 6930p modem card, Battery Removal: étape 1, image 2 de 3 Removing the HP Elitebook 6930p modem card, Battery Removal: étape 1, image 3 de 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p modem card, Keyboard: étape 2, image 1 de 3 Removing the HP Elitebook 6930p modem card, Keyboard: étape 2, image 2 de 3 Removing the HP Elitebook 6930p modem card, Keyboard: étape 2, image 3 de 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p modem card: étape 3, image 1 de 3 Removing the HP Elitebook 6930p modem card: étape 3, image 2 de 3 Removing the HP Elitebook 6930p modem card: étape 3, image 3 de 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p modem card: étape 4, image 1 de 3 Removing the HP Elitebook 6930p modem card: étape 4, image 2 de 3 Removing the HP Elitebook 6930p modem card: étape 4, image 3 de 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p modem card, Modem card: étape 5, image 1 de 2 Removing the HP Elitebook 6930p modem card, Modem card: étape 5, image 2 de 2
    • Locate the modem card and remove the 2 M2.5×4.0 screws
    • The modem card is it is plugged into a connector on the logic board. Gently lift the card up and out of the laptop
    • A plastic spudger may be useful in lifting the card out
    • Be careful as there is a small cable connected to the edge of the modem card closest to the LCD display
    • Disconnect the cable from the modem card to complete removal
Richdave
Membre depuis le 04/09/10
32 063 Réputation
30 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 528 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,385
