First, identify the piece of paper that is causing the jam.
  • First, identify the piece of paper that is causing the jam.
Ajouter un commentaire
Use your hand to remove the jammed piece of paper. Pull until the paper is out. Use your hand to remove the jammed piece of paper. Pull until the paper is out. Use your hand to remove the jammed piece of paper. Pull until the paper is out.
  • Use your hand to remove the jammed piece of paper. Pull until the paper is out.
Do not reuse the piece of paper that caused the jam. Replace the paper with fresh, uncrinkled  paper.
  • Do not reuse the piece of paper that caused the jam. Replace the paper with fresh, uncrinkled paper.
Tim Wise
Membre depuis le 01/04/2011
170 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 10-38, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 membres
10 tutoriels rédigés
my printer is jamming overtime I try to print something. I have cleared paper jams from both the front and back, and it’s still doing it. Any ideas?
Lissa barrett - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 3,696
