Aller au contenu principal
Repairing Nintendo DS Lite Volume Switch
Ce dont vous avez besoin
  1. Repairing Nintendo DS Lite Volume Switch, Battery: étape 1, image 1 de 2 Repairing Nintendo DS Lite Volume Switch, Battery: étape 1, image 2 de 2
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Repairing Nintendo DS Lite Volume Switch: étape 2, image 1 de 1
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Repairing Nintendo DS Lite Volume Switch, Lower Case: étape 3, image 1 de 2 Repairing Nintendo DS Lite Volume Switch, Lower Case: étape 3, image 2 de 2
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Repairing Nintendo DS Lite Volume Switch: étape 4, image 1 de 1
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-Wing screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-Wing screws
  5. Repairing Nintendo DS Lite Volume Switch: étape 5, image 1 de 3 Repairing Nintendo DS Lite Volume Switch: étape 5, image 2 de 3 Repairing Nintendo DS Lite Volume Switch: étape 5, image 3 de 3
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Repairing Nintendo DS Lite Volume Switch: étape 6, image 1 de 1
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
  7. Repairing Nintendo DS Lite Volume Switch, Volume Switch: étape 7, image 1 de 1
    • Carefully use a pair of tweezers to remove the volume switch.
Ligne d'arrivée
4 autres ont terminé cette réparation.
Philip
Membre depuis le 01/20/10
570 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 16-30, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 16-30, Maness Winter 2010
CPSU-MANESS-W10S16G30
4 membres
24 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 71
Total : 10,257
