Introduction
This guide will show you how to remove the back case of the Samsung Galaxy S SCH i500.
Pièces
Aucune pièce nécessaire.
To remove the back case of the Samsung Galaxy S, you may need a spudger. Identify the slit which is at the bottom edge of the phone. Identify the slit which is at the bottom edge of the phone.
  • To remove the back case of the Samsung Galaxy S, you may need a spudger.
  • Identify the slit which is at the bottom edge of the phone.
Ajouter un commentaire
Insert the edge of the spudger into the slit and use it to pry the back case off of the phone. Insert the edge of the spudger into the slit and use it to pry the back case off of the phone.
  • Insert the edge of the spudger into the slit and use it to pry the back case off of the phone.
8 autre(s) ont terminé cette réparation.
Kevin Carlson
Membre depuis le 22/04/2011
236 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 25-25, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-25, Garner Spring 2011
CPSU-GARNER-S11S25G25
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 4,601
