Introduction
How to replace speaker
Turn the phone over so that the screen is facing the work surface
  • Turn the phone over so that the screen is facing the work surface
Ajouter un commentaire
Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
  • Press your thumb against the battery latch. While pressing on latch, slide off battery cover towards the bottom of the phone.
  • You may need to apply considerable force on the latch at the bottom of the phone to complete this successfully.
Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
  • Remove the battery by pushing downward on the area where prongs connect to bottom inside of the phone while using a thumb, finger, or tool to pull on the top of the battery to lift it out.
Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
  • Using the T6 Torx screwdriver, remove the bottom two screws on the back of the phone.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
  • Remove speaker phone cover by unsecuring the two latches on the edge close to top of the phone with the plastic opening tool.
Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
  • Detach the speaker phone cover by pulling up on the bottom of the speaker phone cover.
  • As you detach the speaker phone cover you will notice a sticky glue sealing the rubber gasket from the cover to the speaker mesh. This is normal and will correctly reset the first few times the pieces are separated.
Remove top two screws with T6 Torx screw driver, from the back of phone.
  • Remove top two screws with T6 Torx screw driver, from the back of phone.
Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
  • Turn the phone sideways and unlatch the hinge on one side of the phone by pushing inwards and twisting to the side with the plastic opening tool.
You should now be able to easily separate the phone into two pieces. The battery prong may fall out when the separation occurs, just don't loose it!
  • You should now be able to easily separate the phone into two pieces.
  • The battery prong may fall out when the separation occurs, just don't loose it!
Set aside the bottom part of the phone.
  • Set aside the bottom part of the phone.
  • Drop out the rubber keypad from the top, so that it does not get in the way.
Use the plastic separator tool to apply significant pressure in a downward motion on the top of the white speaker unit.
  • Use the plastic separator tool to apply significant pressure in a downward motion on the top of the white speaker unit.
The speaker unit should become loose.
  • The speaker unit should become loose.
  • You can now push the separating tool beneath the speaker and pop it out.
  • Once the defective unit is removed, pop your new speaker unit back into place.
Sean Tiernan
Membre depuis le 20/01/2010
5 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-16, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 3-16, Maness Winter 2010
CPSU-MANESS-W10S3G16
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,080
