Introduction
Tablet was dropped, failed to power on.Plugged in but screen just flashed.Removed back.Connection for the battery was not seated & battery was at a slight angle.Drop caused plug & battery to unseat.Reseated and put back cover on and it powered up.Easy fix
Note battery compartment slightly larger than battery. 1/8" reveal on left side if off after top of battery shifted.
33 autres ont terminé cette réparation.
4 commentaires
I just did this after dropping my Nexus 7 and experiencing the screen flicker.
Take the back cover off as described here
Remplacement de la batterie du Nexus 7
Ensure the battery plug is connected well. Straighten the battery back up. Worked perfectly.
just tried this, couldn`t find the right tool so used a 1mm guitar pick and credit card. worked perfectly and now my Nexus is working again. thanks.
