Introduction
This is an easy guide to replacing the rear buttons on the Sanyo VPC-X1200.
Remove the five case screws with a Phillips #00 Screwdriver. Five 3.5mm Phillips Screws Five 3.5mm Phillips Screws
  • Remove the five case screws with a Phillips #00 Screwdriver.
  • Five 3.5mm Phillips Screws
Ajouter un commentaire
Gently lift up the back cover and set aside.
  • Gently lift up the back cover and set aside.
Use small plastic pry tool to gently remove rear button plate.
  • Use small plastic pry tool to gently remove rear button plate.
  • A heat gun may be used to soften the glue for easier removal.
Anthony Giardina
Membre depuis le 19/04/2010
20 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-10, Maness Spring 2010
CPSU-MANESS-S10S7G10
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,325
