Aller au contenu principal
Replacing the Slider on a Coil Zipper
Ce dont vous avez besoin
Vidéo d'introduction
  1. Replacing the Slider on a Coil Zipper, Coil Zipper Slider: étape 1, image 1 de 3 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: étape 1, image 2 de 3 Replacing the Slider on a Coil Zipper, Coil Zipper Slider: étape 1, image 3 de 3
    • Locate the top of the zipper on the side with the slider.
    • Peel back any fabric that is covering the zipper stop.
  2. Replacing the Slider on a Coil Zipper: étape 2, image 1 de 2 Replacing the Slider on a Coil Zipper: étape 2, image 2 de 2
    • Use end nippers to cut the stop.
    • Be sure to only cut the plastic or metal stop. You do not want to damage the webbing behind the zipper.
  3. Replacing the Slider on a Coil Zipper: étape 3, image 1 de 1
    • Carefully remove any remaining pieces of the stop using tweezers.
  4. Replacing the Slider on a Coil Zipper: étape 4, image 1 de 3 Replacing the Slider on a Coil Zipper: étape 4, image 2 de 3 Replacing the Slider on a Coil Zipper: étape 4, image 3 de 3
    • Slide the damaged zipper slider up and off of the zipper.
  5. Replacing the Slider on a Coil Zipper: étape 5, image 1 de 2 Replacing the Slider on a Coil Zipper: étape 5, image 2 de 2
    • Slide the replacement slider onto the zipper.
    • You may need to tug a little to get it past where the old stop was.
    • Make sure that your zipper slider is facing the correct way (right-side up) when you place it onto the zipper.
  6. Replacing the Slider on a Coil Zipper: étape 6, image 1 de 2 Replacing the Slider on a Coil Zipper: étape 6, image 2 de 2
    • Grab a new zipper stop.
    • Insert the teeth into the webbing in the same place where the old stop was located.
  7. Replacing the Slider on a Coil Zipper: étape 7, image 1 de 3 Replacing the Slider on a Coil Zipper: étape 7, image 2 de 3 Replacing the Slider on a Coil Zipper: étape 7, image 3 de 3
    • Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
    • Crimp the stop into place.
Ligne d'arrivée
19 autres ont terminé cette réparation.
Brittany McCrigler
Membre depuis le 03/05/12
89 011 Réputation
131 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 731 tutoriels rédigés
11 commentaires
Where do I get the zipper stop????
Jason Heimink - Réponse
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
bbehrhorst - Réponse
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
kasten39828 - Réponse
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Jenny - Réponse
Great now how ! thank’s :)
Robert Fyfe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 19
7 derniers jours : 135
30 derniers jours : 605
Total : 98,533
