Aller au contenu principal
Resetting the Clock
  1. Resetting the Clock, Resetting the Clock: étape 1, image 1 de 1
    • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
  2. Resetting the Clock: étape 2, image 1 de 2 Resetting the Clock: étape 2, image 2 de 2
    • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
  3. Resetting the Clock: étape 3, image 1 de 1
    • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
  4. Resetting the Clock: étape 4, image 1 de 1
    • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
  5. Resetting the Clock: étape 5, image 1 de 1
    • Press the "VOLUME +" button to advance the minutes forward.
  6. Resetting the Clock: étape 6, image 1 de 1
    • Press the "VOLUME -" button to decrease the minutes.
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Jacob Aube
Membre depuis le 09/24/12
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-50, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 1,496
