Aller au contenu principal
Revlon 473 Heating Element Replacement
Ce dont vous avez besoin
  1. Revlon 473 Heating Element Replacement, Shell: étape 1, image 1 de 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: étape 2, image 1 de 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: étape 3, image 1 de 3 Revlon 473 Heating Element Replacement: étape 3, image 2 de 3 Revlon 473 Heating Element Replacement: étape 3, image 3 de 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: étape 4, image 1 de 1
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: étape 5, image 1 de 1
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV.
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
Jessica Leyva
Membre depuis le 09/18/12
143 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-5, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,866
