Aller au contenu principal
Ring Video Doorbell Battery Replacement
Ce dont vous avez besoin
  1. Ring Video Doorbell Battery Replacement, Battery: étape 1, image 1 de 3 Ring Video Doorbell Battery Replacement, Battery: étape 1, image 2 de 3 Ring Video Doorbell Battery Replacement, Battery: étape 1, image 3 de 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1. mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell Battery Replacement: étape 2, image 1 de 3 Ring Video Doorbell Battery Replacement: étape 2, image 2 de 3 Ring Video Doorbell Battery Replacement: étape 2, image 3 de 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Do NOT lift the case of all the way, there is still a cable connecting the two pieces.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
2 autres ont terminé cette réparation.
Abdulrahman
Membre depuis le 02/20/18
685 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 membres
10 tutoriels rédigés
4 commentaires
Where do I get a replacement battery?
William Price - Réponse
I had an issue where the battery would not charge the light when I was trying to charge the battery flashed bue quickly, I removed the battery and found that the connector was corroded after cleaning it and making sure it was connected correctly the battery then took a full charge and now the bell functions as intended once again.
P.S thanks for the guide :)
David Haras - Réponse
Who should the complete unit be sent to for checkup and repairs as it does not work
d.rayyan - Réponse
can it be sent to the manufacturers for a replacement
d.rayyan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 54
30 derniers jours : 240
Total : 8,301
