Introduction
In this guide, you will be shown how to take apart and replace the Motherboard of the Ring Video Doorbell step-by-step. You will need a Phillips screwdriver size PH00 and a Plastic Tool Opener.
Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device. Pry open the aluminium plate using the Plastic Opening Tool(s). Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
  • Pry open the aluminium plate using the Plastic Opening Tool(s).
  • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
Ajouter un commentaire
Pry open the back case as shown using the Plastic Opening Tool. Disconnect the battery from motherboard by carefully pulling up on the connector. Disconnect the battery from motherboard by carefully pulling up on the connector.
  • Pry open the back case as shown using the Plastic Opening Tool.
  • Disconnect the battery from motherboard by carefully pulling up on the connector.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver. Carefully detach the motherboard, from the housing unit using your hands. Carefully detach the motherboard, from the housing unit using your hands.
  • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
  • Carefully detach the motherboard, from the housing unit using your hands.
Detach the upper part of the motherboard from the bottom, using your hands. Detach the upper part of the motherboard from the bottom, using your hands.
  • Detach the upper part of the motherboard from the bottom, using your hands.
Abdulrahman
Membre depuis le 20/02/2018
401 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S11-G5, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 13
Total : 31
