Introduction
This guide will give detailed steps on how to replace the capacitor in the Ring Video Doorbell Pro.
Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
  • Start by using the star-shaped end of the included Ring screwdriver to take out the 5 mm screw on the bottom of the device.
Ajouter un commentaire
Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device. Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device. Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
  • Use your thumbs to apply downward pressure on the glass part of the device while pulling the faceplate up and off of the device.
Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
  • Using a PH-000 screwdriver, unscrew and set aside all four of these 5.25 mm screws.
Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device. Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
  • Using a plastic pry tool, go along the edge of the device prying the device apart. While doing this, focus on the four clips, two of which are on either side of the device.
Remove the front of the device from the back plate.
  • Remove the front of the device from the back plate.
With the Video Doorbell Pro opened up the speaker is exposed.
  • With the Video Doorbell Pro opened up the speaker is exposed.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove this 5.25 mm screw.
  • Remove this 5.25 mm screw.
Remove this wire connection by gently prying it off with a plastic pry tool.
  • Remove this wire connection by gently prying it off with a plastic pry tool.
Remove the speaker from the device.
  • Remove the speaker from the device.
The next step is to remove the last four connections holding the motherboard in place.
  • The next step is to remove the last four connections holding the motherboard in place.
Using the plastic pry tool, carefully remove this wire connection.
  • Using the plastic pry tool, carefully remove this wire connection.
Using the plastic pry tool, gently ease this ribbon cable from its port.
  • Using the plastic pry tool, gently ease this ribbon cable from its port.
Remove the last two wire connections shown here using the same methods utilized in the previous steps.
  • Remove the last two wire connections shown here using the same methods utilized in the previous steps.
Using the Phillips 000 screwdriver, remove these three 4.25mm screws. Using the Phillips 000 screwdriver, remove these three 4.25mm screws.
  • Using the Phillips 000 screwdriver, remove these three 4.25mm screws.
Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
  • Take the motherboard out of the housing. Lift slowly while doing this to make sure the wires and the delicate ribbon cable are not damaged.
Remove the capacitor.
  • Remove the capacitor.
To reassemble your device, insert the new capacitor and follow these instructions in reverse order.
2 autre(s) ont terminé cette réparation.
Jake Dixon
Membre depuis le 09/11/2017
551 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S7-G4, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S7-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S7G4
3 membres
4 tutoriels rédigés
where can I buy the replacement capacitor please or is it a case of buying a standard and making up the lead?
Umesh Radia - Réponse
is that a battery right next to it? why didn’t you pull/mention that also?
Adrian Osio - Réponse
Voir les statistiques:
Dernières 24 heures : 37
7 derniers jours : 90
30 derniers jours : 233
Total : 1,003
