Introduction
This guide will help you remove the power button.
Twist the plastic lid counterclockwise to unlock it. Lift the lid to remove it from the container.
  • Twist the plastic lid counterclockwise to unlock it.
  • Lift the lid to remove it from the container.
Ajouter un commentaire
Carefully remove the blade from the container.
  • Carefully remove the blade from the container.
  • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
  • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Use your fingers to pry out the two rubber feet from the bottom cover of the base.
  • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
  • The two feet furthest from the button tower contain screws. The other two feet do not.
Use the Phillips #2 screwdriver  to unscrew the two 12.7-mm screws underneath the rubber feet. Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
  • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
  • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Firmly lift the bottom cover off of the base.
  • Firmly lift the bottom cover off of the base.
Remove the smaller white gear by lifting it up with your hand.
  • Remove the smaller white gear by lifting it up with your hand.
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base. Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin. Continue turning the gear until completely removed from the blade-shaft.
  • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
  • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
  • Continue turning the gear until completely removed from the blade-shaft.
Use your hand to firmly pull the blade-shaft from the base.
  • Use your hand to firmly pull the blade-shaft from the base.
Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
  • Using Phillips #2 screwdriver, unscrew two 12.7-mm screws in the middle of the base.
Unwind power cord from the base pegs.
  • Unwind power cord from the base pegs.
Use the plastic opening tool to pry open the base from the main body. These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
  • Use the plastic opening tool to pry open the base from the main body.
  • These two plastic prongs are pressed fit into the base. It may take some effort to pry the base completely off.
  • Once freed, lift the base panel from the main body and set it aside.
Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body. Next, turn the device upright and lift the upper casing from around the button gently.
  • Use a Phillips #2 screwdriver to remove the three 9.53-mm screws from inside the main body.
  • Next, turn the device upright and lift the upper casing from around the button gently.
Remove the button by simply pulling it up.
  • Remove the button by simply pulling it up.
  • Don't lose the spring under the button! Without it, the blender will not function.
David Otsu
Membre depuis le 16/10/2013
103 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-29, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 263
