Introduction
This guide is for the removal or installation of the rotary multi selector wheel.
Pièces
Aucune pièce nécessaire.
Unscrew the two 3.5mm Phillips screws from the side with the AV outlet. Unscrew the 3.5mm Phillips screw from the opposite side of the camera. Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
  • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
  • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
Ajouter un commentaire
Carefully remove the back casing from the camera.
  • Carefully remove the back casing from the camera.
  • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up. Gently pull the ribbon from the logic board with tweezers.
  • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
  • Gently pull the ribbon from the logic board with tweezers.
  • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Lift up the metal cover and its button slowly using the tweezers. Lift up the metal cover and its button slowly using the tweezers. Lift up the metal cover and its button slowly using the tweezers.
  • Lift up the metal cover and its button slowly using the tweezers.
Andrew Lau
Membre depuis le 18/04/2013
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-56, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 345
