Introduction
I have a 2007 Saab 9-3 Aero petrol Automatic car. It has been a joy to own and ride, but recently it started to show warning messages:
"Steering lock Malfunction. Please come to a safe stop and call service" (or something like that)
On other occasions, the key would refuse to turn. Disconnecting the battery for a while would sometimes fix the issue, but this was clearly not a safe car to drive any longer.
Googling the issue revealed that there are two components involved in starting the car:
The ISM (Ignition Switch Module) is where the key is inserted.
The CIM (Column Integration Module) is located inside the steering wheel. It is the security centre and controls the central locking, ignition, immobilisation, steering lock etc.
Both of these could be the culprit. However, whereas the ISM _can_ be replaced by a layman (i.e. me!!), the CIM requires both special tools and the electronic equipment to be able to remove and replace, and pair up with a new set of keys.
So, equipped with a Haynes "Saab 9-3 Sept 2007 to 2011 Owners Workshop Manual", a set of star shaped screwdrivers, and a camera to record all the steps, as well as a pile of clear plastic bags to put the screws in and label them (they are all subtly different in size, thread and length), I set about to replace the ISM with a unit I bought on eBay. This involves removing the centre console to get to the ISM itself.
Our starting point: The center console with the ignition switch in the middle
  • Our starting point: The center console with the ignition switch in the middle
Ajouter un commentaire
This is the screwdriver bit used to remove all the screws.
  • This is the screwdriver bit used to remove all the screws.
This is the item we need to replace
  • This is the item we need to replace
Step one is to remove the front side panels. There is a single (covered) screw in the footwell on each side that can be removed, and the panel slides rearwards, down and out.
  • Step one is to remove the front side panels. There is a single (covered) screw in the footwell on each side that can be removed, and the panel slides rearwards, down and out.
Unscrew and remove this screw
  • Unscrew and remove this screw
The panel can now come off.
  • The panel can now come off.
Rear cover is removed next.
  • Rear cover is removed next.
Next, locate the rear cover visible from the back seats, between the two front seats. Pull it sharply to the rear, and remove.
  • Next, locate the rear cover visible from the back seats, between the two front seats. Pull it sharply to the rear, and remove.
The rear side panels in front of the rear cover are now easily accessible and can be removed.
  • The rear side panels in front of the rear cover are now easily accessible and can be removed.
Next, remove the rubber mat in front of the gear lever.
  • Next, remove the rubber mat in front of the gear lever.
The (shiny) gear lever surround trim can now be prized off, starting at the rear, and removed.
  • The (shiny) gear lever surround trim can now be prized off, starting at the rear, and removed.
Removing the gear lever surround trim exposes a single screw holding a retaining frame underneath the gear change mechanism.
  • Removing the gear lever surround trim exposes a single screw holding a retaining frame underneath the gear change mechanism.
Unscrew the retaining screw
  • Unscrew the retaining screw
Remove the retaining frame
  • Remove the retaining frame
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Slide out horizontally the protective plastic cover underneath the hand brake.
  • Slide out horizontally the protective plastic cover underneath the hand brake.
This exposes a single screw. Remove this.
  • This exposes a single screw. Remove this.
On the other side, remove the CD holder top cover,
  • On the other side, remove the CD holder top cover,
unscrew the two screws inside,
  • unscrew the two screws inside,
and remove the CD holder itself. This exposes another single screw. Remove this.
  • and remove the CD holder itself. This exposes another single screw. Remove this.
Remove the bottom rubber cover in the centre console storage unit.
  • Remove the bottom rubber cover in the centre console storage unit.
This exposes two screws that need removing.
  • This exposes two screws that need removing.
The drinks holder has another rubber mat.
  • The drinks holder has another rubber mat.
There are no screws underneath, but this is a good opportunity to remove it and clean it separately.
  • There are no screws underneath, but this is a good opportunity to remove it and clean it separately.
Underneath the air vent controlling air flow to the passengers from the center console sits a square duct.
  • Underneath the air vent controlling air flow to the passengers from the center console sits a square duct.
The Haynes manual suggests pulling this out next, and although it is possible to do so, it requires force, and is much easier to do later when all other fixings have been removed.
  • The Haynes manual suggests pulling this out next, and although it is possible to do so, it requires force, and is much easier to do later when all other fixings have been removed.
There are two cable bundles connected to the center console from the rest of the car. One is connected via a large, square plug with a red tab.
  • There are two cable bundles connected to the center console from the rest of the car. One is connected via a large, square plug with a red tab.
Push a screwdriver inside the red tab and pull, and the connector splits neatly apart.
  • Push a screwdriver inside the red tab and pull, and the connector splits neatly apart.
The other is an earth connector near the rear of the console. This can easily be pulled away.
  • The other is an earth connector near the rear of the console. This can easily be pulled away.
Remove two screws located in front of the gear lever.
  • Remove two screws located in front of the gear lever.
The next bit is a bit fiddly to get to: There are two screws going horizontally, one underneath the handbrake,
  • The next bit is a bit fiddly to get to: There are two screws going horizontally, one underneath the handbrake,
the other on the CD holder side. These need to be removed. There is limited workspace. Use a separate loose screwdriver bit, and a spanner to twist it.
  • the other on the CD holder side. These need to be removed. There is limited workspace. Use a separate loose screwdriver bit, and a spanner to twist it.
The center console is now loose, and can be puller backwards and upwards, and removed from the car. The center console is now loose, and can be puller backwards and upwards, and removed from the car. The center console is now loose, and can be puller backwards and upwards, and removed from the car.
  • The center console is now loose, and can be puller backwards and upwards, and removed from the car.
Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket. Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket. Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket.
  • Tip the centre console upside down and locate the ISM ignition switch.There are four spring clips holding it in place. Use a screwdriver to compress each clip in turn, whilst pushing the switch out of its socket.
The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector. The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector. The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector.
  • The switch is connected to a cable via a connector. Locate the torque lever and twist this to release the connector.
You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again. You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again.
  • You now have the ISM in your hand. Swap this with a replacement unit. Mine cost £126,00 new from eBay. Clip it in the same spot, and connect the cable again.
  • The rest of the procedure is doing the dismantling in reverse. However, this is the best order that I found (choosing the wrong order once or twice):
The square air conditioning duct goes in first. The console goes in next. It is a bit awkward to riggle past all the lugs, screws, tabs and cables, but just persevere. Once in, fit all the screws holding it in place, including the awkward ones.
  • The square air conditioning duct goes in first. The console goes in next. It is a bit awkward to riggle past all the lugs, screws, tabs and cables, but just persevere. Once in, fit all the screws holding it in place, including the awkward ones.
Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed. Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed. Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed.
  • Connect the two cables. The earth connector is push-on, and the square plug self-locks when the red tab is pushed.
  • Next, fit the retaining frame underneath the gear lever, all screws around it, then the shiny gear lever surround trim, and finally the rubber mat in front of it. Fit the side rear panels, then the front panels (fasten them with the single screw), then the rear cover.
With all side panels in place, re-fit the screws around the gear lever and CD holder. Finally, slide the handbrake cover in place, and screw the CD holder in. All rubber mats put in place (you *did* clean them whilst you had the chance, right..?).  You are done!
  • With all side panels in place, re-fit the screws around the gear lever and CD holder. Finally, slide the handbrake cover in place, and screw the CD holder in. All rubber mats put in place (you *did* clean them whilst you had the chance, right..?). You are done!
  • Touch Wood, my car is now purring, with none of the issues I had before. Having heard quotes from around £1,000 upwards for a complete ISM / CIM refit, I am well pleased with the result.
Lars Erlandsen
Membre depuis le 17/04/2018
553 Réputation
1 tutoriel rédigé
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 35
Total : 54
