Aller au contenu principal
Saab 9-5 97-2010 Turbo Replacement
Ce dont vous avez besoin
  1. Saab 9-5 97-2010 Turbo Replacement, Final Checks: étape 3, image 1 de 1
    • Once you have refitted your Turbo and reconnected all hoses and filters you need to check a few things:
    • Check the oil level - this will certainly need topping up. Bear in mind that you will need to replace the oil and filter within 500 miles.
    • Ensure your coolant and all other fluids are topped off to ensure they will not cause any problems in general operation.
    • Run the motor
    • Pay close attention to coolant levels and any warning on the instrument cluster
    • There may still be oil in the exhaust system, this will start to burn as the vehicle warms up.
    • If you notice smoke immediately (from a cold engine) stop the motor immediately and check all your connections. This could be an indication that oil is getting burnt in the turbo.
    • If all looks ok and the car is brought up to temperature, while idling, gently increase the revs up and down over the course of a few minutes - shut down and check for leaks. You are done!
Andrew Armstrong
Membre depuis le 05/23/18
625 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 808
