Pièces
Aucune pièce nécessaire.
Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
  • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
  • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
Ajouter un commentaire
Remove the seven screws that are holding in the battery.  They can be seen circled in the picture. When unscrewed, lift the battery.  There will be a cable connected to the battery.  Detach this cable from the board and remove the battery. Attach the replacement battery cable to the board and reassemble.  It can be seen highlighted in picture 2.
  • Remove the seven screws that are holding in the battery. They can be seen circled in the picture.
  • When unscrewed, lift the battery. There will be a cable connected to the battery. Detach this cable from the board and remove the battery.
  • Attach the replacement battery cable to the board and reassemble. It can be seen highlighted in picture 2.
  • *Note: When reinserting the battery it is easier to put in the long end first and then dropping the other side in.
3 autre(s) ont terminé cette réparation.
Garrett Kissinger
Membre depuis le 24/02/2014
692 Réputation
5 tutoriels rédigés
Équipe
Michigan Tech, Team 1-2, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 membres
5 tutoriels rédigés
Samsung 500C ChromeBook Battery where to buy?
Uzi Naveh - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 32
Total : 1,880
