Pièces
Aucune pièce nécessaire.
Remove the back panel of the device by taking out the seven screws on the back panel of the device. Four of the screws are under the rubber feet so they will need to be removed.  To remove the feet, pry them off with the spudger.
  • Remove the back panel of the device by taking out the seven screws on the back panel of the device.
  • Four of the screws are under the rubber feet so they will need to be removed. To remove the feet, pry them off with the spudger.
Ajouter un commentaire
Note: The Speaker is held in with an adhesive back so some force will be needed to remove it. Remove the speaker using a spudger and detach the cord connected to it from the laptop.  The speaker location is seen highlighted in picture 1.
  • Note: The Speaker is held in with an adhesive back so some force will be needed to remove it.
  • Remove the speaker using a spudger and detach the cord connected to it from the laptop. The speaker location is seen highlighted in picture 1.
  • Attach the cord of your replacement speaker and reassemble the device.
Garrett Kissinger
Membre depuis le 24/02/2014
692 Réputation
5 tutoriels rédigés
Équipe
Michigan Tech, Team 1-2, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 1-2, Lauer Spring 2014
MTU-LAUER-S14S1G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 776
