Aller au contenu principal
Samsung ATIV Book 9 Plus Charger Port Replacement
Ce dont vous avez besoin
  1. Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: étape 1, image 1 de 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: étape 1, image 2 de 3 Samsung ATIV Book 9 Plus Charger Port Replacement, Back Cover: étape 1, image 3 de 3
    • Turn the laptop upside down so that the underside of the laptop is facing you.
    • Use a Phillips #000 screwdriver to unscrew the 4.3 mm screws located on the edges and corners of the laptop.
  2. Samsung ATIV Book 9 Plus Charger Port Replacement: étape 2, image 1 de 1
    • Lift the cover to reveal the interior of the laptop.
  3. Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: étape 3, image 1 de 2 Samsung ATIV Book 9 Plus Charger Port Replacement, Charger Port: étape 3, image 2 de 2
    • Unscrew the 4.3mm screws holding down the plastic cover using a #000 screwdriver. After the screws are out remove the cover.
    • Remove the 4.3 mm screw holding down the metal cover using a #000 screwdriver.
  4. Samsung ATIV Book 9 Plus Charger Port Replacement: étape 4, image 1 de 1
    • Disconnect the charging port from the motherboard by gently tugging on the plastic part of the connection.
  5. Samsung ATIV Book 9 Plus Charger Port Replacement: étape 5, image 1 de 1
    • Wedge a plastic opening tool or spudger in between the laptop casing and the port. Pry until you feel it release.
    • This will take some force because the port is glued to the casing.
  6. Samsung ATIV Book 9 Plus Charger Port Replacement: étape 6, image 1 de 1
    • Remove the disconnected charger port.
3 autres ont terminé cette réparation.
Casey Kauffman
Membre depuis le 11/06/17
329 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S6-G6, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S6-G6, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G6
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 4
Total : 1,911
