Introduction
Installing a new battery may help if your phone has a low battery life or if it powers off randomly.
To remove the back casing, firmly press down and push towards the bottom of the phone. To remove the back casing, firmly press down and push towards the bottom of the phone. To remove the back casing, firmly press down and push towards the bottom of the phone.
  • To remove the back casing, firmly press down and push towards the bottom of the phone.
Ajouter un commentaire
With the casing removed, lift the battery from the indicated indentation.
  • With the casing removed, lift the battery from the indicated indentation.
From here, you can now access the SIM card and model/serial numbers.
  • From here, you can now access the SIM card and model/serial numbers.
Breanne
Membre depuis le 12/04/2012
187 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-24, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 6-24, Amido Spring 2012
CPSU-AMIDO-S12S6G24
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 680
