Introduction
This guide shows you how to replace the camera on your phone.
Pièces
Aucune pièce nécessaire.
Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
  • Use your fingernail or the plastic opening tool under the slit to pull the back cover off.
Ajouter un commentaire
Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
  • Making sure your hands are dry, insert your fingernail beneath the battery and remove it.
Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone. Place the screws on a magnetic mat to prevent losing them. Place the screws on a magnetic mat to prevent losing them.
  • Use a Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  • Place the screws on a magnetic mat to prevent losing them.
Place the Plastic Opening tool on the outside rim of the back cover. Carefully circle around the rim to open the inside back cover completely. Disconnect the ribbon cables and remove the back cover.
  • Place the Plastic Opening tool on the outside rim of the back cover.
  • Carefully circle around the rim to open the inside back cover completely.
  • Disconnect the ribbon cables and remove the back cover.
Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard. Pull back the side clips and lift the motherboard slowly. Pull back the side clips and lift the motherboard slowly.
  • Carefully disconnect the volume button, the microphone connector, and the screen connector from the motherboard.
  • Pull back the side clips and lift the motherboard slowly.
Use the plastic opening tool to disconnect the camera from the phone. Connect the new camera into the motherboard.
  • Use the plastic opening tool to disconnect the camera from the phone.
  • Connect the new camera into the motherboard.
10 autre(s) ont terminé cette réparation.
Thao Uyen Do
Membre depuis le 20/01/2015
812 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 887
