Pièces
Aucune pièce nécessaire.
To open the back cover of the phone, use your fingernail or plastic opening tool under the slit to pull the cover up.
  • To open the back cover of the phone, use your fingernail or plastic opening tool under the slit to pull the cover up.
Ajouter un commentaire
Carefully remove the battery by placing your fingernail underneath the hole and pull out the battery.
  • Carefully remove the battery by placing your fingernail underneath the hole and pull out the battery.
  • Your hands should not be wet.
Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone. Be careful not to lose the screws, so place them on a magnetic mat. Be careful not to lose the screws, so place them on a magnetic mat.
  • Use the Phillips #00 Precision Screwdriver to remove the six screws in the back of the phone.
  • Be careful not to lose the screws, so place them on a magnetic mat.
Use the Plastic Opening tools to remove the inside back cover. Place the Plastic Opening tools on the outside rim of the inside back cover. Carefully lift the cover and circle around the rim to open the inside back cover completely.
  • Use the Plastic Opening tools to remove the inside back cover.
  • Place the Plastic Opening tools on the outside rim of the inside back cover.
  • Carefully lift the cover and circle around the rim to open the inside back cover completely.
  • Carefully disconnect ribbon cables and slowly lift the inside back cover to remove it.
Lift the motherboard slowly. Carefully disconnect the volume button away from the motherboard. Disconnect the two ribbon cables from the back of the motherboard.
  • Lift the motherboard slowly.
  • Carefully disconnect the volume button away from the motherboard.
  • Disconnect the two ribbon cables from the back of the motherboard.
  • Remove the motherboard completely from the phone
7 autre(s) ont terminé cette réparation.
Thao Uyen Do
Membre depuis le 20/01/2015
812 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 861
