Aller au contenu principal
Samsung Admire Screen Replacement
Ce dont vous avez besoin
  1. Samsung Admire Screen Replacement, Screen: étape 1, image 1 de 1
    • Slide your fingernail or plastic opening tool under the slit and pull the cover up.
  2. Samsung Admire Screen Replacement: étape 2, image 1 de 1
    • Place your fingernail or plastic tool into the hole beneath the camera and carefully lift out the battery.
  3. Samsung Admire Screen Replacement: étape 3, image 1 de 3 Samsung Admire Screen Replacement: étape 3, image 2 de 3 Samsung Admire Screen Replacement: étape 3, image 3 de 3
    • Use a Phillips #00 precision screwdriver to remove the six screws from the back of the phone.
  4. Samsung Admire Screen Replacement: étape 4, image 1 de 3 Samsung Admire Screen Replacement: étape 4, image 2 de 3 Samsung Admire Screen Replacement: étape 4, image 3 de 3
    • Use the plastic opening tool to remove the inside back cover.
    • Use the plastic opening to pry the front and the back case apart.
    • As you lift the cover, move the plastic tool around the phone to pry up all of the screen.
    • Carefully disconnect the ribbon cables and slowly lift the inside back cover to remove it.
  5. Samsung Admire Screen Replacement: étape 5, image 1 de 3 Samsung Admire Screen Replacement: étape 5, image 2 de 3 Samsung Admire Screen Replacement: étape 5, image 3 de 3
    • Lift the motherboard slowly.
    • Carefully disconnect the volume button from the motherboard.
    • Disconnect the two ribbon cables from the back of the motherboard.
  6. Samsung Admire Screen Replacement: étape 6, image 1 de 3 Samsung Admire Screen Replacement: étape 6, image 2 de 3 Samsung Admire Screen Replacement: étape 6, image 3 de 3
    • Pull back on the five clips on the sides of the phone to remove the shield.
    • Be careful not to break the ribbon cables.
  7. Samsung Admire Screen Replacement: étape 7, image 1 de 3 Samsung Admire Screen Replacement: étape 7, image 2 de 3 Samsung Admire Screen Replacement: étape 7, image 3 de 3
    • Use the plastic opening tool to unlatch the ribbon cable to disconnect it.
    • Place the plastic opening tool under the edge of the screen and lift the screen up carefully.
  8. Samsung Admire Screen Replacement: étape 8, image 1 de 1
    • Insert new screen into the phone frame and reconnect the ribbon cable.
    • Follow steps in reverse order (omitting step eight) to reassemble the phone.
12 autres ont terminé cette réparation.
Thao Uyen Do
Membre depuis le 01/20/15
896 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 7-5, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-5, Remmell Winter 2015
USFT-REMMELL-W15S7G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 5
Total : 1,596
