Introduction
A guide on how to replace a damaged DC power board on a Samsung BD-7500.
Pièces
Aucune pièce nécessaire.
Remove the three 10mm screws with a Phillips #0 screwdriver.
  • Remove the three 10mm screws with a Phillips #0 screwdriver.
  • Pry the top off with a plastic opening tool.
Ajouter un commentaire
Remove the three screws holding down the cover with a Phillips #0 screwdriver.
  • Remove the three screws holding down the cover with a Phillips #0 screwdriver.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Lift up the power cord at its base to remove it.
  • Lift up the power cord at its base to remove it.
Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
  • Insert a plastic opening tool into the black plastic tab on the cord and twist to separate.
Remove the 7mm screw with a Phillips #1 screwdriver.
  • Remove the 7mm screw with a Phillips #1 screwdriver.
  • Grip the blue tab attached to the base and pull upwards.
Grip the edges of the motherboard and pull upwards to remove.
  • Grip the edges of the motherboard and pull upwards to remove.
samer odeh
Membre depuis le 13/02/2018
313 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S16-G4, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 29
