Introduction
This guide will show how the replacement of the disk reader is done.
Use Phillips 0 Screwdriver to remove two (2) 10 mm rear screws. Use a plastic prying tool to help separate the top plastic casing from the bottom metal casing. When opening the device,  pay attention to the ribbon cable circled in image 3.
  • Use Phillips 0 Screwdriver to remove two (2) 10 mm rear screws.
  • Use a plastic prying tool to help separate the top plastic casing from the bottom metal casing.
  • When opening the device, pay attention to the ribbon cable circled in image 3.
Ajouter un commentaire
Use Phillips 0 screwdriver to remove two (2) 10 mm screws from the plastic cover Remove plastic cover from board. Remove plastic cover from board.
  • Use Phillips 0 screwdriver to remove two (2) 10 mm screws from the plastic cover
  • Remove plastic cover from board.
Pull up on back of wire to  dislocate black tab piece from device. To remove the cord from the device entirely, press on the white tab in the device and gently pull.
  • Pull up on back of wire to dislocate black tab piece from device.
  • To remove the cord from the device entirely, press on the white tab in the device and gently pull.
Insert plastic prying tool into black tab on power cord, and use leverage to open the black tab.
  • Insert plastic prying tool into black tab on power cord, and use leverage to open the black tab.
  • Pull the tab off the wire so that it can be placed on the replacement cord.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the two 10mm screws with a Phillips #1 screwdriver. Separate the two pieces with a plastic opening tool.
  • Remove the two 10mm screws with a Phillips #1 screwdriver.
  • Separate the two pieces with a plastic opening tool.
firmly grip the hard plastic tab attached to the base and pull upwards. It is important no to tear the ribbon cables. firmly grip the hard plastic tab attached to the base and pull upwards. It is important no to tear the ribbon cables. firmly grip the hard plastic tab attached to the base and pull upwards. It is important no to tear the ribbon cables.
  • firmly grip the hard plastic tab attached to the base and pull upwards. It is important no to tear the ribbon cables.
Remove the two 7mm screws with a Phillips #1 screwdriver. Remove the two 7mm screws with a Phillips #1 screwdriver.
  • Remove the two 7mm screws with a Phillips #1 screwdriver.
Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
  • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
Flip up the black locking tab on the ZIF connector. Flip up the black locking tab on the ZIF connector. Flip up the black locking tab on the ZIF connector.
  • Flip up the black locking tab on the ZIF connector.
Remove the 10 mm screw using head #J1 screwdriver. Remove the small metal bar by pulling it outwards. Remove the small metal bar by pulling it outwards.
  • Remove the 10 mm screw using head #J1 screwdriver.
  • Remove the small metal bar by pulling it outwards.
Flip the disc tray over so the laser points downward. Pull the disc reader out of the disc tray.
  • Flip the disc tray over so the laser points downward.
  • Pull the disc reader out of the disc tray.
Livan Perez
Membre depuis le 15/02/2018
253 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S16-G4, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 19
Total : 54
