Introduction
This guide will show you how to open up the device to remove and replace the disc tray.
Pièces
Aucune pièce nécessaire.
Remove the two 10mm screws with a Phillips #1 screwdriver. Use the plastic prying tool to separate the top plastic casing from the bottom metal casing.
  • Remove the two 10mm screws with a Phillips #1 screwdriver.
  • Use the plastic prying tool to separate the top plastic casing from the bottom metal casing.
Ajouter un commentaire
Grip the blue tab and pull upwards to remove the ribbon cable from the motherboard. If it feels stuck, wiggle it while pulling gently to coerce it out. If it feels stuck, wiggle it while pulling gently to coerce it out.
  • Grip the blue tab and pull upwards to remove the ribbon cable from the motherboard.
  • If it feels stuck, wiggle it while pulling gently to coerce it out.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove  the two 7mm screws with a Phillips #1 screwdriver.
  • Remove the two 7mm screws with a Phillips #1 screwdriver.
Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove. Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
  • Pinch both tabs on the side of the disc tray, push towards the front, and lift the disc tray out to remove.
Livan Perez
Membre depuis le 15/02/2018
253 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S16-G4, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G4, Boczar Spring 2018
USFT-BOCZAR-S18S16G4
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 23
