Introduction
Is your Blu-ray player not able to play your favorite flicks due to a faulty disc drive? If so, all you need is a #1 Phillips screwdriver and this guide to show how to replace the DVD disc tray with a new one.
Pièces
Aucune pièce nécessaire.
Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
  • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
  • Tilt the back of the top cover forward to remove from chassis.
Ajouter un commentaire
Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
  • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
  • Be careful not to damage the ribbon cable by using too much force.
Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
  • Using a #1 Phillips head screwdriver, remove the two 7.5 mm screws (one not shown) near the front that secures the disc tray to the chassis.
Push two small prongs on either side of disc tray inwards and push disc tray forward.
  • Push two small prongs on either side of disc tray inwards and push disc tray forward.
Remove disc tray
  • Remove disc tray
Louis McKean
Membre depuis le 18/10/2017
501 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G21, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 95
