Aller au contenu principal
Samsung BD-F5900 Main Logic Board Replacement
Ce dont vous avez besoin
  1. Samsung BD-F5900 Main Logic Board Replacement, Top Cover: étape 1, image 1 de 1
    • Using a #1 Phillips head screwdriver, remove the three 10mm screws on the back panel.
    • Tilt the back of the top cover forward to remove from chassis.
  2. Samsung BD-F5900 Main Logic Board Replacement: étape 2, image 1 de 1
    • Gently pull up on the ribbon cable by the blue tab to remove it from the power supply board.
  3. Samsung BD-F5900 Main Logic Board Replacement, Power Supply: étape 3, image 1 de 2 Samsung BD-F5900 Main Logic Board Replacement, Power Supply: étape 3, image 2 de 2
    • Using a #1 Phillips head screwdriver, remove the two 7.5mm screws on top of the plastic cover and remove the cover.
  4. Samsung BD-F5900 Main Logic Board Replacement: étape 4, image 1 de 1
    • Press down on the plastic retaining clip and pull backwards to remove the AC power connector from the power supply board.
  5. Samsung BD-F5900 Main Logic Board Replacement: étape 5, image 1 de 3 Samsung BD-F5900 Main Logic Board Replacement: étape 5, image 2 de 3 Samsung BD-F5900 Main Logic Board Replacement: étape 5, image 3 de 3
    • Using the plastic spudger tool, gently pry on either side of main power connector (CON801) to disconnect from main logic board.
    • Pry a little bit on each side of board until the board lifts away.
    • Tilt the board forward and lift up to remove from the chassis.
  6. Samsung BD-F5900 Main Logic Board Replacement, Main Logic Board: étape 6, image 1 de 1
    • Remove the two ribbon cables from the Main Logic Board assembly by gently pulling up on the blue tab.
    • Be careful not to damage the ribbon cable by using too much force.
  7. Samsung BD-F5900 Main Logic Board Replacement: étape 7, image 1 de 1
    • Disconnect the WiFi board cable connector
  8. Samsung BD-F5900 Main Logic Board Replacement: étape 8, image 1 de 2 Samsung BD-F5900 Main Logic Board Replacement: étape 8, image 2 de 2
    • Using a #1 Phillips head screwdriver, remove the three 7.5 mm screws from the board
    • Also remove the 10 mm screw from the rear panel.
    • Remove the Main Logic Board
Louis McKean
Membre depuis le 10/18/17
528 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G21, Cagle Fall 2017 Membre de l'équipe USF Tampa, Team S1-G21, Cagle Fall 2017
USFT-CAGLE-F17S1G21
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 382
