Introduction
Use this guide to remove the volume/scroll wheel.
Ce dont vous avez besoin
Hold the device with the screen facing away from you and the camera towards you.
Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
Place your fingers on both sides of the bottom of the battery and lift upwards.
Pull the battery away from the phone.
Use the spudger to remove the rubber stoppers from the top of the cover.
Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
Use the screwdriver to unscrew the four screws that hold the scroll wheel in place.
Use your fingers to remove the scroll wheel and the metal plate that it is attached to.
