Aller au contenu principal
Samsung Chromebook 2 Screen Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 2 Screen Replacement, Battery: étape 1, image 1 de 1
    • Make sure your Chromebook is turned off before you begin.
    • Set the labtop face down on a flat surface.
  2. Samsung Chromebook 2 Screen Replacement: étape 2, image 1 de 3 Samsung Chromebook 2 Screen Replacement: étape 2, image 2 de 3 Samsung Chromebook 2 Screen Replacement: étape 2, image 3 de 3
    • Remove the nine 5 mm screws on the bottom cover using a Phillips #0 screwdriver.
  3. Samsung Chromebook 2 Screen Replacement: étape 3, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 3, image 2 de 2
    • Loosen the back cover panel with a plastic opening tool, and work it all the way around the computer.
  4. Samsung Chromebook 2 Screen Replacement: étape 4, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 4, image 2 de 2
    • Once the cover is loose, remove the back cover panel using your hands.
  5. Samsung Chromebook 2 Screen Replacement: étape 5, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 5, image 2 de 2
    • Unscrew the four 4 mm screws holding the battery in place with a Phillips #0 screwdriver.
  6. Samsung Chromebook 2 Screen Replacement: étape 6, image 1 de 3 Samsung Chromebook 2 Screen Replacement: étape 6, image 2 de 3 Samsung Chromebook 2 Screen Replacement: étape 6, image 3 de 3
    • Disconnect the wire that connects the battery to the motherboard by pulling upward.
  7. Samsung Chromebook 2 Screen Replacement, Screen: étape 7, image 1 de 2 Samsung Chromebook 2 Screen Replacement, Screen: étape 7, image 2 de 2
    • Replace the back cover by clicking it into place with your hands.
    • No need to replace the screws, this is just to protect the internal hardware while working on the screen.
  8. Samsung Chromebook 2 Screen Replacement: étape 8, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 8, image 2 de 2
    • Open the laptop and place it so that the back of the screen is laying on a flat surface.
    • Insert a plastic opening tool between the front cover and plastic screen trim.
    • Work the plastic opening tool all around the trim.
    • Don't be afraid to use your hands to pull the trim from the front panel.
  9. Samsung Chromebook 2 Screen Replacement: étape 9, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 9, image 2 de 2
    • Flip the computer over so that the keys and screen are facing down.
    • Insert the spudger between the back and front panel, at the hinge, and push the trim out.
  10. Samsung Chromebook 2 Screen Replacement: étape 10, image 1 de 1
    • Place the laptop in a position where it is resting on the back of the screen.
    • Remove the trim from the front panel by pulling up with your hands.
  11. Samsung Chromebook 2 Screen Replacement: étape 11, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 11, image 2 de 2
    • Using a Phillips #0 screwdriver to unscrew the four 3 mm screws keeping the screen in place.
  12. Samsung Chromebook 2 Screen Replacement: étape 12, image 1 de 2 Samsung Chromebook 2 Screen Replacement: étape 12, image 2 de 2
    • Using the spudger, pry the screen loose from the front panel.
    • Do not try to remove the screen yet, it is still connect by a wire.
  13. Samsung Chromebook 2 Screen Replacement: étape 13, image 1 de 3 Samsung Chromebook 2 Screen Replacement: étape 13, image 2 de 3 Samsung Chromebook 2 Screen Replacement: étape 13, image 3 de 3
    • Place the laptop in an upright position.
    • When you place the Chromebook in this position the screen may fall off, so make sure to hold onto it.
    • Pull back the screen to locate the LCD cable, and disconnect it by pulling the black tape that surrounds it towards you.
  14. Samsung Chromebook 2 Screen Replacement: étape 14, image 1 de 1
    • Pull the screen from the front panel using your hands to fully remove it.
10 autres ont terminé cette réparation.
MacKenzie Colson
Membre depuis le 01/25/16
611 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team 1-3, Rose Winter 2016 Membre de l'équipe UW Tacoma, Team 1-3, Rose Winter 2016
UWT-ROSE-W16S1G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 13
Total : 7,175
