Aller au contenu principal
Samsung Chromebook 3 Trackpad Replacement
Ce dont vous avez besoin
  1. Samsung Chromebook 3 Trackpad Replacement, Bottom Case: étape 1, image 1 de 2 Samsung Chromebook 3 Trackpad Replacement, Bottom Case: étape 1, image 2 de 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Trackpad Replacement: étape 2, image 1 de 3 Samsung Chromebook 3 Trackpad Replacement: étape 2, image 2 de 3 Samsung Chromebook 3 Trackpad Replacement: étape 2, image 3 de 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Trackpad Replacement: étape 3, image 1 de 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Trackpad Replacement, Battery: étape 4, image 1 de 2 Samsung Chromebook 3 Trackpad Replacement, Battery: étape 4, image 2 de 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Trackpad Replacement: étape 5, image 1 de 2 Samsung Chromebook 3 Trackpad Replacement: étape 5, image 2 de 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Trackpad Replacement: étape 6, image 1 de 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Trackpad Replacement, Trackpad: étape 7, image 1 de 3 Samsung Chromebook 3 Trackpad Replacement, Trackpad: étape 7, image 2 de 3 Samsung Chromebook 3 Trackpad Replacement, Trackpad: étape 7, image 3 de 3
    • Remove the three 2.3mm screws along the top of the trackpad using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Trackpad Replacement: étape 8, image 1 de 2 Samsung Chromebook 3 Trackpad Replacement: étape 8, image 2 de 2
    • Use a spudger to gently remove the adhesive tape on the upper left side of the trackpad.
  9. Samsung Chromebook 3 Trackpad Replacement: étape 9, image 1 de 2 Samsung Chromebook 3 Trackpad Replacement: étape 9, image 2 de 2
    • There's more adhesive on the cable ribbon on the upper left side that connects the trackpad to the motherboard. Use your spudger to lift the cable ribbon up from the adhesive.
  10. Samsung Chromebook 3 Trackpad Replacement: étape 10, image 1 de 3 Samsung Chromebook 3 Trackpad Replacement: étape 10, image 2 de 3 Samsung Chromebook 3 Trackpad Replacement: étape 10, image 3 de 3
    • Use a spudger to lift the grey plastic piece locking the cable ribbon in place to its connection on the motherboard.
    • The grey piece is on a hinge and should be able to be flipped up rather than removed completely. Removal doesn't damage anything, just makes putting everything back together a bit harder, so try not to remove if possible.
    • Take the end of the cable ribbon out from the connector.
  11. Samsung Chromebook 3 Trackpad Replacement: étape 11, image 1 de 2 Samsung Chromebook 3 Trackpad Replacement: étape 11, image 2 de 2
    • From the keyboard side, nudge the trackpad down and around the lip on the upper edge and finally pull your trackpad out to freedom!
Austin Blakely
Membre depuis le 03/11/19
19 631 Réputation
53 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
136 membres
17 292 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 25
Total : 981
