Aller au contenu principal
Samsung Epic 4G Power Button Replacement
Ce dont vous avez besoin
  1. Samsung Epic 4G Power Button Replacement, Phone Case: étape 1, image 1 de 1
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
  2. Samsung Epic 4G Power Button Replacement: étape 2, image 1 de 1
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
  3. Samsung Epic 4G Power Button Replacement, Battery: étape 3, image 1 de 1
    • Remove the battery from the device by pulling the battery edge upwards.
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: étape 4, image 1 de 1
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: étape 5, image 1 de 2 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: étape 5, image 2 de 2
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: étape 6, image 1 de 2 Samsung Epic 4G Power Button Replacement, Removing the Power Button: étape 6, image 2 de 2
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
Andrew Cunningham
Membre depuis le 10/03/12
273 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 24-25, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 24-25, Regan Fall 2012
CPSU-REGAN-F12S24G25
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 14
Total : 2,284
