Aller au contenu principal
Samsung Galaxy Attain 4G Rear Housing Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Attain 4G Rear Housing Replacement, Placement: étape 1, image 1 de 1
    • Begin by turn the device over to it's back, with the screen facing down.
  2. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: étape 2, image 1 de 2 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Door Removal: étape 2, image 2 de 2
    • At the top of the device there is a small notch that is used to remove the battery door.
    • Using a pry tool or your fingernail, pry off the battery door from the main housing.
  3. Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: étape 3, image 1 de 3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: étape 3, image 2 de 3 Samsung Galaxy Attain 4G Rear Housing Replacement, Battery Removal: étape 3, image 3 de 3
    • Place the battery door to the side.
    • Using a pry tool or your fingernail, pry the battery up towards you.
    • You have now removed the battery!
  4. Samsung Galaxy Attain 4G Rear Housing Replacement, Heads Up!: étape 4, image 1 de 1
    • Make sure when replacing the battery that the arrow on the bottom is facing down.
  5. Samsung Galaxy Attain 4G Rear Housing Replacement, Screw Removal: étape 5, image 1 de 1
    • Remove the 6 Phillips head screws that hold the rear housing in place.
  6. Samsung Galaxy Attain 4G Rear Housing Replacement, Prying: étape 6, image 1 de 1
    • Using a spudger or plastic pry tool, slowly go around the phone between the display & rear housing to release the clips.
  7. Samsung Galaxy Attain 4G Rear Housing Replacement, Remove Housing: étape 7, image 1 de 1
    • Lift the rear housing from the display assembly.
4 autres ont terminé cette réparation.
Josh Forester
Membre depuis le 11/28/10
2 497 Réputation
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 282
