Introduction
Outline what you are going to teach someone how to do.
Insert a finger nail or plastic opening tool between the back cover and the device.
  • Insert a finger nail or plastic opening tool between the back cover and the device.
  • Gently pry the rear cover off of the back of the phone.
Ajouter un commentaire
Using a finger, pull the SIM card down out of its slot. Remove the SIM card.
  • Using a finger, pull the SIM card down out of its slot.
  • Remove the SIM card.
  • The pictured device is missing the SIM card and battery.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
Insert a plastic opening tool between the screen and the back of the device. Starting at the bottom of the device, gently slide the tool along the edges of the screen. Gently pry the main assembly from the midframe of the device.
  • Insert a plastic opening tool between the screen and the back of the device.
  • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
  • Gently pry the main assembly from the midframe of the device.
  • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
Use the flat end a spudger to disconnect the front-facing camera cable connecter. Use the flat end a spudger to disconnect the front-facing camera cable connecter.
  • Use the flat end a spudger to disconnect the front-facing camera cable connecter.
Using tweezers, or your fingers, remove the front-facing camera. Using tweezers, or your fingers, remove the front-facing camera.
  • Using tweezers, or your fingers, remove the front-facing camera.
Sean Kramer
Membre depuis le 14/02/2018
709 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 27
30 derniers jours : 118
Total : 155
