Aller au contenu principal
Samsung Galaxy J1 Motherboard Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy J1 Motherboard Replacement, Midframe: étape 1, image 1 de 1
    • Insert a finger nail or plastic opening tool between the back cover and the device.
    • Gently pry the rear cover off of the back of the phone.
  2. Samsung Galaxy J1 Motherboard Replacement: étape 2, image 1 de 2 Samsung Galaxy J1 Motherboard Replacement: étape 2, image 2 de 2
    • Using a finger, pull the SIM card down out of its slot.
    • Remove the SIM card.
    • The pictured device is missing the SIM card and battery.
  3. Samsung Galaxy J1 Motherboard Replacement: étape 3, image 1 de 1
    • Using a Phillips #00 screwdriver remove the eleven 3 mm screws.
  4. Samsung Galaxy J1 Motherboard Replacement: étape 4, image 1 de 3 Samsung Galaxy J1 Motherboard Replacement: étape 4, image 2 de 3 Samsung Galaxy J1 Motherboard Replacement: étape 4, image 3 de 3
    • Insert a plastic opening tool between the screen and the back of the device.
    • Starting at the bottom of the device, gently slide the tool along the edges of the screen.
    • Gently pry the main assembly from the midframe of the device.
    • When removing the main assembly, pry gently so as to not crack the glass screen or break any clips within the device.
  5. Samsung Galaxy J1 Motherboard Replacement, Motherboard: étape 5, image 1 de 2 Samsung Galaxy J1 Motherboard Replacement, Motherboard: étape 5, image 2 de 2
    • Use the flat edge of a spudger to disconnect the ear speaker connector.
  6. Samsung Galaxy J1 Motherboard Replacement: étape 6, image 1 de 2 Samsung Galaxy J1 Motherboard Replacement: étape 6, image 2 de 2
    • Use the flat end of a spudger disconnect the digitizer connector.
  7. Samsung Galaxy J1 Motherboard Replacement: étape 7, image 1 de 2 Samsung Galaxy J1 Motherboard Replacement: étape 7, image 2 de 2
    • Use the flat end of a spudger disconnect the front-facing camera cable connector.
  8. Samsung Galaxy J1 Motherboard Replacement: étape 8, image 1 de 2 Samsung Galaxy J1 Motherboard Replacement: étape 8, image 2 de 2
    • Remove the front-facing camera.
  9. Samsung Galaxy J1 Motherboard Replacement: étape 9, image 1 de 3 Samsung Galaxy J1 Motherboard Replacement: étape 9, image 2 de 3 Samsung Galaxy J1 Motherboard Replacement: étape 9, image 3 de 3
    • Use the flat end of a spudger to gently pry under the motherboard.
    • Remove the motherboard.
  10. Samsung Galaxy J1 Motherboard Replacement: étape 10, image 1 de 1
    • Use the flat end of a spudger to disconnect the rear camera cable connector.
  11. Samsung Galaxy J1 Motherboard Replacement: étape 11, image 1 de 2 Samsung Galaxy J1 Motherboard Replacement: étape 11, image 2 de 2
    • Remove the rear camera.
22 autres ont terminé cette réparation.
Sean Kramer
Membre depuis le 02/14/18
1 452 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S5G4
3 membres
6 tutoriels rédigés
4 commentaires
can you plz give use a amazon link to part
Sean Gynn - Réponse
Very good illustration..where can I get a motherboard?
Isaac Samuels - Réponse
Where can I get a motherboard for this phone Samsung J100?
I need the details of the motherboard
FUN FIRST - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 38
Total : 6,624
