Introduction
Use this guide to replace the earpiece speaker.
Pièces
Aucune pièce nécessaire.
Before removing the back cover, make sure the Samsung Galaxy Light is switched off.
  • Before removing the back cover, make sure the Samsung Galaxy Light is switched off.
  • Using a plastic opening tool, lift up the back cover of the device.
  • Remove the back cover.
Ajouter un commentaire
Using your finger, remove the battery from the device.
  • Using your finger, remove the battery from the device.
Using a Phillips #0 screwdriver, remove 9 screws.
  • Using a Phillips #0 screwdriver, remove 9 screws.
Using the plastic opening tool, separate the midframe from the front panel of the device.
  • Using the plastic opening tool, separate the midframe from the front panel of the device.
  • Remove the midframe.
To detach the motherboard from the device: Using the plastic opening tool, remove the connector from the motherboard. Carefully lift the motherboard up and move it toward the left side of the device.
  • To detach the motherboard from the device:
    • Using the plastic opening tool, remove the connector from the motherboard.
    • Carefully lift the motherboard up and move it toward the left side of the device.
    • Using the plastic opening tool, remove the connector on the back side of the motherboard.
Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly. Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
  • Use a plastic opening tool to pry up the headphone jack, vibrator, and earpiece speaker assembly.
4 autre(s) ont terminé cette réparation.
Paul Goyette
Membre depuis le 21/10/2014
418 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 5-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 470
