Aller au contenu principal
Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: étape 1, image 1 de 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Case: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Spudger
    $2.99
    J'achète
    • Using the nylon spudger or plastic opening tool along the edges of the screen, separate the back case off of the device.
    • If possible, consider using the black nylon spudger for a gentler separation.
  2. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: étape 2, image 1 de 2 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, Loudspeaker Modules: étape 2, image 2 de 2
    • Remove the three 3mm screws on the top right side of the device with the Phillips PH000 screw head.
    • Remove the one 3mm screw on the top left side of the device with the same method.
  3. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: étape 3, image 1 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: étape 3, image 2 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement, loudspeaker  - remove right speaker: étape 3, image 3 de 3
    • Remove the gray rubber piece.
    • Use a spudger or fingernail to disconnect the blue antenna cable from the motherboard.
    • Remove the right speaker unit.
  4. Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: étape 4, image 1 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: étape 4, image 2 de 3 Samsung Galaxy Note 10.1 2014 Loudspeaker Modules Replacement: étape 4, image 3 de 3
    • Remove the loudspeaker modules located on the parts where the screws were removed by using the black nylon spudger.
    • They are the black pieces at the top left and right corners of the device that have metal squares on them in the middle.
4 autres ont terminé cette réparation.
Joseph Rasico
Membre depuis le 02/20/17
2 173 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Leahy Spring 2017 Membre de l'équipe USF Tampa, Team S1-G6, Leahy Spring 2017
USFT-LEAHY-S17S1G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 18
Total : 1,625
