Aller au contenu principal
Samsung Galaxy Note 10.1 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: étape 1, image 1 de 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: étape 1, image 2 de 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Top Piece: étape 1, image 3 de 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: étape 2, image 1 de 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: étape 2, image 2 de 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Back Cover: étape 2, image 3 de 3
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: étape 3, image 1 de 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: étape 3, image 2 de 3 Samsung Galaxy Note 10.1 Rear Facing Camera Replacement, Removing the Camera: étape 3, image 3 de 3
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
3 autres ont terminé cette réparation.
Bryan Fernandez
Membre depuis le 09/22/14
241 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-7, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 3-7, Brown Fall 2014
USFT-BROWN-F14S3G7
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 14
Total : 2,182
