Aller au contenu principal
Samsung Galaxy Note 3 Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove the rear case: étape 1, image 1 de 1
    • Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
  2. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: étape 2, image 1 de 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Case from the Base: étape 2, image 2 de 2
    • Slide your fingernail or plastic opening tool along the edge of the rear case.
    • Lift the case gently from the base.
  3. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: étape 3, image 1 de 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Battery: étape 3, image 2 de 2
    • Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
    • Lift the battery out of its recess.
  4. Samsung Galaxy Note 3 Rear Facing Camera Replacement, S Pen: étape 4, image 1 de 1
    • Place your fingernail in the groove of the stylus pen.
    • Pull the stylus pen away from the phone.
  5. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unscrew Back Chassis: étape 5, image 1 de 1
    • Remove the twelve 4mm Phillips #00 screws from the back chassis.
  6. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Remove Back Chassis: étape 6, image 1 de 1
    • Insert the plastic opening tool into the Stylus Pen placement holder.
    • Lift the plastic opening tool so that the midframe separates from the base.
  7. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: étape 7, image 1 de 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Screw Removal: étape 7, image 2 de 2
    • Remove the single screw beside headphone jack.
  8. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: étape 8, image 1 de 2 Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unfasten Clips and Cable Connectors: étape 8, image 2 de 2
    • Use tweezers to remove both antenna clips.
    • Use a spudger to disconnect six cable connectors.
  9. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Motherboard Removal: étape 9, image 1 de 1
    • Pull up on the motherboard with tweezers.
  10. Samsung Galaxy Note 3 Rear Facing Camera Replacement, Unclipping the Camera: étape 10, image 1 de 1
    • Unclip the camera connecting cable using the plastic opening tool from the motherboard
    • Remove loose camera from base
37 autres ont terminé cette réparation.
Brittany Gail
Membre depuis le 09/23/14
8 504 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 2-2, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 2-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G2
4 membres
25 tutoriels rédigés
3 commentaires
Awesome, phone disassembly and fingernail painting at same time :) Thanks for your time to post this!
Chris G - Réponse
Hi
Thanks for the nice instructions
Do you know if I can use a Note 4 camera (or any better!) for my Note 3?
Are they different in connections?
Thanks
hameidfehri - Réponse
I shall be very thankfull for this act of kindness
Malik wajdan ali - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 13,430
