Aller au contenu principal
Samsung Galaxy Note Display Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note Display Assembly Replacement, Stylus: étape 1, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Stylus: étape 1, image 2 de 2
    • Grasp the cap of the stylus and remove it from its slot in the midframe.
  2. Samsung Galaxy Note Display Assembly Replacement, Rear Case: étape 2, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Rear Case: étape 2, image 2 de 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
  3. Samsung Galaxy Note Display Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 3, image 2 de 2
    • Lift and remove the rear case from the phone.
  4. Samsung Galaxy Note Display Assembly Replacement, Battery: étape 4, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Battery: étape 4, image 2 de 2
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
  5. Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: étape 5, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: étape 5, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement, MicroSD Card: étape 5, image 3 de 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  6. Samsung Galaxy Note Display Assembly Replacement: étape 6, image 1 de 1
    • Remove the microSD card from its slot in the midframe.
  7. Samsung Galaxy Note Display Assembly Replacement, SIM Card: étape 7, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement, SIM Card: étape 7, image 2 de 2
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
  8. Samsung Galaxy Note Display Assembly Replacement: étape 8, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 8, image 2 de 2
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
  9. Samsung Galaxy Note Display Assembly Replacement, Midframe: étape 9, image 1 de 1
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  10. Samsung Galaxy Note Display Assembly Replacement: étape 10, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 10, image 2 de 2
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
  11. Samsung Galaxy Note Display Assembly Replacement: étape 11, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 11, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 11, image 3 de 3
    • Slide the plastic opening tool down the seam.
  12. Samsung Galaxy Note Display Assembly Replacement: étape 12, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 12, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 12, image 3 de 3
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
  13. Samsung Galaxy Note Display Assembly Replacement: étape 13, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 13, image 2 de 2
    • Remove the midframe from the display assembly.
  14. Samsung Galaxy Note Display Assembly Replacement, Motherboard Assembly: étape 14, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement, Motherboard Assembly: étape 14, image 2 de 2
    • Use the flat end of a spudger to carefully disconnect the display cable connector.
  15. Samsung Galaxy Note Display Assembly Replacement: étape 15, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 15, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 15, image 3 de 3
    • Use a spudger to disconnect the front-facing camera assembly cable connector.
    • Disconnect the headphone jack/earpiece speaker assembly cable connector.
    • Disconnect the digitizer cable connector.
  16. Samsung Galaxy Note Display Assembly Replacement: étape 16, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 16, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 16, image 3 de 3
    • Disconnect the soft button cable connector with the flat end of a spudger.
    • Use a spudger to disconnect the USB board cable connector.
    • Disconnect the antenna cable connector.
  17. Samsung Galaxy Note Display Assembly Replacement: étape 17, image 1 de 1
    • Remove the two 3.4 mm Phillips #00 screws securing the motherboard to the display assembly.
  18. Samsung Galaxy Note Display Assembly Replacement: étape 18, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 18, image 2 de 2
    • Remove the motherboard assembly from the display assembly.
  19. Samsung Galaxy Note Display Assembly Replacement, Display Assembly: étape 19, image 1 de 1
    • Remove the two 3 mm Phillips #00 screws securing the upper display assembly bracket.
  20. Samsung Galaxy Note Display Assembly Replacement: étape 20, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 20, image 2 de 2
    • Use a pair of tweezers, or your fingers, to remove the upper display assembly bracket.
  21. Samsung Galaxy Note Display Assembly Replacement: étape 21, image 1 de 1
    • Using tweezers, or your fingers, remove the front-facing camera assembly.
  22. Samsung Galaxy Note Display Assembly Replacement: étape 22, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 22, image 2 de 2
    • Use the tip of a spudger to pry the headphone jack/earpiece speaker assembly out of its recess in the display assembly.
  23. Samsung Galaxy Note Display Assembly Replacement: étape 23, image 1 de 1
    • Use tweezers, or your fingers, to remove the headphone jack/earpiece speaker assembly.
  24. Samsung Galaxy Note Display Assembly Replacement: étape 24, image 1 de 1
    • Remove the three 3 mm Phillips #00 screws securing the speaker enclosure to the front panel assembly.
  25. Samsung Galaxy Note Display Assembly Replacement: étape 25, image 1 de 1
    • Lift the speaker enclosure from the display assembly.
  26. Samsung Galaxy Note Display Assembly Replacement: étape 26, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 26, image 2 de 2
    • Use the tip of a spudger to disconnect the antenna cable connector from the USB board.
    • Remove the antenna cable.
  27. Samsung Galaxy Note Display Assembly Replacement: étape 27, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 27, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 27, image 3 de 3
    • Push the flat end of a spudger under the USB board to separate it from the display assembly.
    • Insert the spudger at a shallow angle to avoid bending or damaging the USB board.
  28. Samsung Galaxy Note Display Assembly Replacement: étape 28, image 1 de 1
    • Remove the USB board.
  29. Samsung Galaxy Note Display Assembly Replacement: étape 29, image 1 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 29, image 2 de 3 Samsung Galaxy Note Display Assembly Replacement: étape 29, image 3 de 3
    • Insert the tip of a spudger under the vibrator connector cable near the contacts then slide toward the vibrator itself.
  30. Samsung Galaxy Note Display Assembly Replacement: étape 30, image 1 de 2 Samsung Galaxy Note Display Assembly Replacement: étape 30, image 2 de 2
    • Insert the flat end of a spudger under the vibrator connector cable, and pry it up from the adhesive.
  31. Samsung Galaxy Note Display Assembly Replacement: étape 31, image 1 de 1
    • Remove the vibrator from the display assembly.
42 autres ont terminé cette réparation.
Sam Goldheart
Membre depuis le 10/18/12
465 789 Réputation
538 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 820 tutoriels rédigés
6 commentaires
étape 31 ensuite ??
Fabrice - Réponse
i have a galaxy not and its display is badly broken,at the top of the phone(front side),the display is broken so badly that i am able to a little circuit i.e. a brown color wire which is connected to the display.
so my ques. is that can the phone work after repairing or it has gone?
Abhishek Kumbhar - Réponse
Hello Abhishek Kumbhar, if the motherboard is not damaged it's all fine. All other parts are replaceable
Georg Fischer - Réponse
excellent photos
of samsung 717
murali maroju - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 23
Total : 44,135
