Aller au contenu principal
Samsung Galaxy Note5 Display Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: étape 1, image 1 de 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: étape 2, image 1 de 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: étape 3, image 1 de 1
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: étape 4, image 1 de 1
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Display Replacement: étape 5, image 1 de 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: étape 6, image 1 de 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: étape 7, image 1 de 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: étape 8, image 1 de 1
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: étape 9, image 1 de 2 Samsung Galaxy Note5 Display Replacement: étape 9, image 2 de 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Display Replacement: étape 10, image 1 de 3 Samsung Galaxy Note5 Display Replacement: étape 10, image 2 de 3 Samsung Galaxy Note5 Display Replacement: étape 10, image 3 de 3
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: étape 11, image 1 de 1
    • Loosen the two signal cable connectors.
  12. Samsung Galaxy Note5 Display Replacement: étape 12, image 1 de 3 Samsung Galaxy Note5 Display Replacement: étape 12, image 2 de 3 Samsung Galaxy Note5 Display Replacement: étape 12, image 3 de 3
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
  13. Samsung Galaxy Note5 Display Replacement: étape 13, image 1 de 1
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: étape 14, image 1 de 1
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: étape 15, image 1 de 3 Samsung Galaxy Note5 Display Replacement: étape 15, image 2 de 3 Samsung Galaxy Note5 Display Replacement: étape 15, image 3 de 3
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
  16. Samsung Galaxy Note5 Display Replacement: étape 16, image 1 de 1
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: étape 17, image 1 de 1
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: étape 18, image 1 de 1
    • The display is now removed.
37 autres ont terminé cette réparation.
Alexander Laucius
Membre depuis le 04/19/18
1 536 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S25-G17, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 membres
5 tutoriels rédigés
6 commentaires
Worked like a charm
Ronald Sapp - Réponse
How does one bond everything back together?
lcplthomasc - Réponse
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 30
30 derniers jours : 120
Total : 23,973
