Aller au contenu principal
Samsung Galaxy R Speaker Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy R Speaker Assembly Replacement, Rear Case: étape 1, image 1 de 3 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: étape 1, image 2 de 3 Samsung Galaxy R Speaker Assembly Replacement, Rear Case: étape 1, image 3 de 3
    • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
    • Gently pry apart the rear case from the midframe and remove.
  2. Samsung Galaxy R Speaker Assembly Replacement, Battery: étape 2, image 1 de 3 Samsung Galaxy R Speaker Assembly Replacement, Battery: étape 2, image 2 de 3 Samsung Galaxy R Speaker Assembly Replacement, Battery: étape 2, image 3 de 3
    • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
    • Gently pry the battery from the back of the phone.
  3. Samsung Galaxy R Speaker Assembly Replacement, Remove screws: étape 3, image 1 de 2 Samsung Galaxy R Speaker Assembly Replacement, Remove screws: étape 3, image 2 de 2
    • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
    • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  4. Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: étape 4, image 1 de 3 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: étape 4, image 2 de 3 Samsung Galaxy R Speaker Assembly Replacement, Bottom Panel: étape 4, image 3 de 3
    • Insert an opening tool underneath the bottom panel near the bottom left side of the back of the phone.
    • Gently pry the part of the motherboard that is pointed out in the picture to the left from underneath the part of the phone that it is latched under.
    • Gently lift the bottom panel from the back of the phone.
  5. Samsung Galaxy R Speaker Assembly Replacement, Top Panel: étape 5, image 1 de 3 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: étape 5, image 2 de 3 Samsung Galaxy R Speaker Assembly Replacement, Top Panel: étape 5, image 3 de 3
    • Use tweezers to grasp the vibrator piece firmly and pull it away from the top panel with enough force to break the glue bond.
    • Insert an opening tool underneath the top panel near the top left side of the back of the phone.
    • Gently lift the panel from the back of the phone.
  6. Samsung Galaxy R Speaker Assembly Replacement, Speaker: étape 6, image 1 de 3 Samsung Galaxy R Speaker Assembly Replacement, Speaker: étape 6, image 2 de 3 Samsung Galaxy R Speaker Assembly Replacement, Speaker: étape 6, image 3 de 3
    • The speaker is located near the top of the phone underneath the motherboard circled in red.
    • To remove the speaker, gently pull on the strap attached until it releases from the phone.
2 autres ont terminé cette réparation.
Daniel Hawkins
Membre depuis le 10/13/14
334 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 3-3, Benson Fall 2014 Membre de l'équipe Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 391
