Introduction
This guide will help you replace the LCD screen or your motherboard on your Samsung Galaxy Rush. It is not a lengthy process and you will have a brand new screen in about 30 minutes.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Looking at the back of your phone, use your finger to remove back cover. Looking at the back of your phone, use your finger to remove back cover.
  • Looking at the back of your phone, use your finger to remove back cover.
Ajouter un commentaire
Remove the battery. Remove the battery.
  • Remove the battery.
With a small phillips-head screw driver, remove the six screws holding the back panel in place.
  • With a small phillips-head screw driver, remove the six screws holding the back panel in place.
Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity. Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
  • Use the pry tool to pry the back panel from the rest of the phone. Pry from the edge closest to the screen for simplicity.
Using tweezers, gently lift connectors from motherboard. A connector will be on the upper left
  • Using tweezers, gently lift connectors from motherboard.
  • A connector will be on the upper left
  • The second connector is located towards the top of the phone. Above the camera. It comes off with ease.
Use the tweezers to carefully remove the 2 adhesive orange ribbons. These stay attached to the motherboard so be careful not to break them.
  • Use the tweezers to carefully remove the 2 adhesive orange ribbons.
  • These stay attached to the motherboard so be careful not to break them.
  • They are on the side of the phone.
Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
  • Use a philips-head screwdriver to remove the single screw on the bottom of the phone. Located to the right of the charging port.
Lift the motherboard upwards separating it from your screen.
  • Lift the motherboard upwards separating it from your screen.
Kenny Afiadata
Membre depuis le 20/10/2014
36 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-4, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G4
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 447
