Aller au contenu principal
Samsung Galaxy S Blaze Display Assembly Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: étape 1, image 1 de 3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: étape 1, image 2 de 3 Samsung Galaxy S Blaze Display Assembly Replacement, Power Button: étape 1, image 3 de 3
    • Start by removing the back plastic cover by lifting it up from the notch on the left side of the phone
  2. Samsung Galaxy S Blaze Display Assembly Replacement: étape 2, image 1 de 1
    • Remove the battery and use a small Phillips head screwdriver to remove the marked up screws
  3. Samsung Galaxy S Blaze Display Assembly Replacement: étape 3, image 1 de 2 Samsung Galaxy S Blaze Display Assembly Replacement: étape 3, image 2 de 2
    • Use a flat tool to pry the two plastic cases apart
    • The latches are very strong, so don't be afraid to use force
  4. Samsung Galaxy S Blaze Display Assembly Replacement: étape 4, image 1 de 3 Samsung Galaxy S Blaze Display Assembly Replacement: étape 4, image 2 de 3 Samsung Galaxy S Blaze Display Assembly Replacement: étape 4, image 3 de 3
    • Locate the missing button slot
    • Place in replacement button, and close the plastic housing around it
    • The button should be fully functional now, repeat past steps to reassemble the phone
  5. Samsung Galaxy S Blaze Display Assembly Replacement, Display Assembly: étape 5, image 1 de 1
    • Gently remove the 2 ribbon cables as shown.
    • Connect the new screen to the main motherboard just the same way it was connected before.
    • Be careful not to crimp or bend the ribbon cables, as this will ruin the replacement.
2 autres ont terminé cette réparation.
Dustin
Membre depuis le 03/12/14
1 213 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,161
